In xamDataGrid, can I get a column containing read-write properties to behave the same was as read-only properties do? I have set the field to be read-only, and whereas it's true that the value can't be edited, the field does appear differently when it has focus. This does not happen with fields based on read-only properties. Assuming it's relatively easy (i.e. without having to create templates for different states), how would I do that?
Thanks!
Brad.
Hello Brad,
Thank you for the feedback. I am glad, that you have found a solution to your issue.
Thanks for your help, but I have this working already. :)
I have been looking into your post.
Would you please provide me with a screenshot of the appearance you want to achieve for the XamDataGrids Field when the 'IsEnabled' property is set to false.
This way I would be able to further investigate this matter for you and provide you with further information on this matter.
I should have been much more clear as to what I need. I know how to set the properties for a disabled field. What I don't know is what the properties are for a field that is read-only. I can guess that the background should be white, but maybe it's transparent, or maybe (more likely) it's a system color or something.
Here is an example of the style, that can be set to change the appearance of the cells when the 'IsEnabled' property is set for a Field. In this style I create a trigger to set the desired properties only if the 'IsEnabled' property is set to 'False':
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Style.Triggers>
<Trigger Property="IsEnabled" Value="False">
<Setter Property="Background" Value="Red"/>
<Setter Property="Foreground" Value="Black"/>
</Trigger>
</Style.Triggers>
</Style>
Please do not hesitate to let me know if you have any further questions on this matter.
