Hi, I'm trying to show a welcome screen when the application is launched, just like (MS Office 2013). But, I have problems with XamRibbonWindow title bar. Please see attachment. Would it be possible to handle the xam ribbon window like Office 2013 app for welcome screen. Please help. Let me know if you need any information
Hi Mahantesh,
I noticed a private support case with number C-00236753 has recently been created on the same matter. Please, note that according to our support policy we handle a single support request/forum thread per question. This is to ensure better tracking and that all your issues are addressed correctly. Having this in mind, I can suggest continuing this discussion in the support case, where I have already provided some suggestions. Thank you for understanding.
Best regards,Bozhidara PachilovaAssociate Software Developer
Hi
I am trying with same example and its woks perfectly.
Apart from this want to achieve below things, can you confirm is it possible to do or not.
Can you please help on this.
Hello Sreek,
Just checking in, did you have any other questions or concerns on this matter?
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Thank you for your post!
I would recommend that you take a look at the sample project I have attached, as well as this article in our online documentation about usage of the ApplicationMenu2010 in the XamRibbon: http://help.infragistics.com/Help/Doc/WPF/2013.1/CLR4.0/html/xamRibbon_DefiningAnApplicationMenu2010.html.
The project that I have attached closely follows that article, and I cannot seem to reproduce the behavior you are seeing with the title bar in it. I have also created this project such that the ApplicationMenu2010 "welcome screen" shows at the start of the application. You can set this by setting the IsOpen property of the ApplicationMenu2010 to True.
