I have added Combo Editor in my project. In one project Combo Editor working fine but in Second project, I found error I am not sure where I am missing. Please let we aware. I have lost my most of the time for that.
I have attached Screen Shots for that.
I am just checking your progress on the issue that you are having.
If you require any further assistance please do not hesitate to ask
Hello Kanwar,
Thank you for your post.
I have been looking into it and it seems that the behavior that you have described is the similar as the behavior from the following forum thread:
http://es.infragistics.com/community/forums/t/95977.aspx
Could you please take a look at the sample application from the thread and try to reproduce the issue with it. If you are not able to reproduce the issue with the attached sample application from the thread, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
