Hi there,
is there a simple solution to bind a xamdatachart to a dataset?
I'm not experienced in the WPF controls and did it formerly in ASP.NET
Any hint is highly appreciated!
Thanks in advance!
Oliver
no, all fine, thanks.
Hello Oliver,
Just checking in, did you have any other questions or concerns on this matter?
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Thank you for your post.
Currently, binding the XamDataChart to a Dataset is not supported. Instead, I would recommend that you bind to the Default View of the DataTables contained inside of your data set. If you would like to see the ability to bind the XamDataChart to a dataset possibly included in the control in a future version, consider placing a new product idea for this functionality at http://ideas.infragistics.com.
