I am using XamGrid in XamTile. When I set the Height and Width for the XamGrid, it loads and scrolls horizonally/vertically good.
If I don't set the Height & width of the XamGrid, it loads in 2-3 minutes (may be not virtualizing). I cannot set the height/width because it takes from whole XamTile size.
Question:
Is there any property which tells whether or not the XamGrid is virtualizing? How can handle this scenario where the XamGrid or its container cannot have fixed height width? Is veritualization possible here?What other test I can do load XamGrid faster. It is read-only with some Group Columns hierarchy which are created at the runtime.
version 14.1 with SP1.
Hello Gajender,
I am checking if this is still an issue for you.
If you require any further assistance please do not hesitate to ask.
Hi Gajender,
Thank you for your post. I have been looking into your question and the virtualization of the XamGrid cannot be turn on/off by setting a property. Could you please try to set the Height and the Width of the XamGrid like:
Height="{Binding RelativeSource={RelativeSource AncestorType={x:Type ig:XamTile}}, Path=Height}"
Width="{Binding RelativeSource={RelativeSource AncestorType={x:Type ig:XamTile}}, Path=Width}"
If the issue still occurs, could you please a sample application that shows the issue in order to investigate it on my side?
