I am using a XamRichTextEditor and a ListView whose items are draggable. I would like to insert a string in the document when the user drops an element on the XamRichTextEditor. For that, i use the DragSource and DropTarget elements from the Infragistics framework.
In the DragSource.Drop event handler, I can use the GetPosition() method on the DropEventArgs to get the Point where the Drop occured (relative to the XamRichTextEditor). My problem is that i can't find a way to get a DocumentOffset or a TextPosition or a TextRange for this Point that I could use to insert the text in the right place inside the document.
Is there a way to acheive this ?
Note: the WinRT native ITextDocument has a GetRangeFromPoint method that does just that and works perfectly.
Note 2: The WPF native RichTextBox has a GetPositionFromPoint method that does just that and also works perfectly. Unfortunatly I can't use the native RichTextBox control because its support for some advanced Rtf formatting options is not good enough for what i want to achieve and the XamRichTextEditor seems to handle them better.
Thank you for your help.
Hi jjh,
I created a private support case for you so that we can discuss your request for a private build. The details have been provided in the case.
The case number is CAS-158096-G0V9L4 and you can view it here.
Thank you very much for taking the time to implement this. The ETA is very much apreciated.
One last question : do you give access to beta builds if we want to test the functionalities being developed ?
Again, thank you for your time.
Hi -
Thanks for bringing this to our attention. This feature has now been scheduled and will be available in the next Service Release which is scheduled to be available on September 11.
Joe
It's been nearly 3 months since i've submited this request. Do you have more information ?
Thank you for your time.
Hello jjh,
I have been looking into your question and into the link for the idea. Currently our developers are reviewing this idea. When there is a change in the status of the idea, you would receive a notification for that change.
Please do not hesitate to let me know if you have any further questions on this matter.
