960
Binding EditingSettings AllowEditing to The View Model
I want to activate/deactivate editing on a XamGrid from the menu, usually, to toggle a Xaml property using the view model (DataContext) I use Binding and a Converter. I've tried the following code:
<ig:XamGrid.EditingSettings>
  <ig:EditingSettings
      AllowEditing="{Binding Path=IsInEditMode, Converter={StaticResource boolToEditingTypeConverter}, Mode=OneWay}"
      IsMouseActionEditingEnabled="DoubleClick"
      IsEnterKeyEditingEnabled="True"
      IsF2EditingEnabled="True"
      IsOnCellActiveEditingEnabled="False" />
</ig:XamGrid.EditingSettings>
Where IsInEditMode is a property on my Viewmodel specifically a DependencyProperty.
The Converter is never called so I presume the binding path is not found. Maybe because the object path is not connected to the model but something else...
Can you tell me where I'm wrong?
thank you
Sabrina
