1640
Binding.DoNothing overrides current theme
I'm setting the forecolor of of a field based on another field of the record using a IValueConverter only under the condition that the ShowColor field of the record is a string that can represents a Color. It goes like this:
<igDP:CellBinding Property="Foreground" Target="CellValuePresenter"
Binding="{Binding Path=DataItem.ShowColor, Converter={StaticResource colorToForeBrushConverter}}"/>
And the ColorToForeBrushConverter goes like this:
public class ColorToForeBrushConverter : IValueConverter
    public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
        if (value is Color)
            return new SolidColorBrush((Color)value);
        else if (value is string)
            string ColorString = (string)value;
            if (ColorString == "") //no specified Foreground
                return Binding.DoNothing
            else
                return new SolidColorBrush((Color)(ColorConverter.ConvertFromString(ColorString)));
    public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
       var color = new Color();
       if (value is SolidColorBrush)
              color = (value as SolidColorBrush).Color;
       return color;
The problem is:
1. Does igDP:CellBinding support conditions?  Meaning to use the ColorToForeBrushConverter only If the DataItem.ShowColor !="".
2. If problem 1 cannot be achieved, ColorToForeBrushConverter returns Binding.DoNothing when DataItem.ShowColor is"" to avoid binding. And this overrides all theme based colors, the Foreground is always Black then. But I don't want it to be black, I want it still be theme specified color, which could vary with themes. How can I achieve this?
Thank you.
Parents Reply Children
No Data
