Hello Support,
In our code we have a functionality on the EditMode Ending event of the Xamdatagrid. In this event we have few validations, only if the validation checks are satisfied the application will proceed to save the data into the database. In case the validation fails we do "e.cancel" and replace the previously set value to the cell.
When we add an invalid entry in the cell/grid and then try to close the application the e.cancel method displays following error message. Can you please suggest a way to avoid this error.
A first chance exception of type 'System.NotSupportedException' occurred in InfragisticsWPF4.DataPresenter.v14.2.dll
Additional information: Can't cancel ending edit mode if it is forced
If there is a handler for this exception, the program may be safely continued.
Thank you for your post. I have been looking into it and I can suggest you handle the Window’s Closing event, which will fire before the EditModeEnding and in there you can set a flag that the app will going to close. Then you can use that flag in the EditModeEnding event handler and doesn’t cancel the event. I created a sample project for you with this approach. Please let me know if this helps you or you have further questions on this matter.
