Every so often, users report this error. It is from Infragistics.WPF4.Controls.Menus.XamDataTree 14.2. It looks like there is an internal error happening in the XamDataTree, but I (so Far) haven't been able to reproduce it. What does this stack trace mean? Every time i run the offending process, it works fine.
System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Controls.Menus.IntermediateNodesManager.get_DataCount()
at Infragistics.Controls.Menus.NodesManager.Infragistics.IProvideDataItems<Infragistics.Controls.Menus.XamDataTreeNode>.get_DataCount()
at Infragistics.Collections.BindableItemCollection`1.GetCount()
at Infragistics.Collections.CollectionBaseEnumerator`1.System.Collections.IEnumerator.MoveNext()
at Infragistics.AutomationPeers.XamDataTreeNodeAutomationPeer.GetChildrenCore()
at System.Windows.Automation.Peers.AutomationPeer.EnsureChildren()
at System.Windows.Automation.Peers.AutomationPeer.UpdateChildrenInternal(Int32 invalidateLimit)
at System.Windows.Automation.Peers.AutomationPeer.UpdateChildren()
at Infragistics.AutomationPeers.XamDataTreeNodeAutomationPeer.Node_PropertyChanged(Object sender, PropertyChangedEventArgs e)
at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
at Infragistics.DependencyObjectNotifier.OnPropertyChanged(String propertyName)
at Infragistics.Controls.Menus.XamDataTreeNode.OnElementReleased(XamDataTreeNodeControl element)
at Infragistics.DependencyObjectRecyclingContainer`1.Infragistics.ISupportRecycling.OnElementReleased(FrameworkElement elem)
at Infragistics.RecyclingManager.PanelInfo.ReleaseElement(ISupportRecycling obj)
at Infragistics.Controls.Menus.Primitives.NodesPanel.ReleaseNode(XamDataTreeNode node, Boolean removeManager)
at Infragistics.Controls.Menus.Primitives.NodesPanel.ResetNodes(Boolean releaseAll)
at Infragistics.Controls.Menus.XamDataTree.XamDataTree_Unloaded(Object sender, RoutedEventArgs e)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastUnloadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Hi Michael,
Do you have a private support case already open for this? If so, you can give me the number and I'll link your case to the dev issue as well.
Following this, as I have also raised a support issue on this, but couldn't reliably reproduce.
Yeah, that was an error on my part. Sorry about that. In the excitement of obtaining a reproducible sample I didn't read through what you said clearly enough. Thanks for setting me straight.
Yes, i will can use my workaround in the meantime. It is actually commenting out the .Clear of the collection for the workaround. So the fix is to NOT clear it, I believe you erroneously stated above the fix was to clear it, it is just the opposite. If you look in the sample i provided, there are comments in the ConfirmClose method in CompareBillingVM.cs, you will find a comment '
//this ClearAll method is the offender, commenting it out fixes the problem'
commenting out that line allows the code to run without the exception. Inside of ClearAll(), the bound collection is cleared inside a dispatcher.
Thanks again, I am looking forward to a resolution.
Hi Travis,
Thanks to your sample I was able to reproduce the exception exactly. Since I have reproduced the issue now I have created a private case for you so that I can link the logged development issue to the case so you can view the status of it. The case number is CAS-147911-Z2W3T8 and the development issue ID is 186133. You can view the case here.
You mentioned that if you clear the collection the issue no longer occurs. Is this a workaround you can use in your application in the mean time?
