Hi all
How can I get all tabitemEx from tablecontrol here?
<igWpf:XamRibbonWindow x:Class="CustomCopyNas.Dialog.FolderDialog" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igWpf="http://schemas.infragistics.com/xaml/wpf" xmlns:classes="clr-namespace:CustomCopyNas.Classes" Title="FolderDialog" Height="500" Width="400" ResizeMode="NoResize" Loaded="FolderDialog_OnLoaded"> <igWpf:RibbonWindowContentHost x:Name="contentHost" Theme="Office2013" igWpf:RibbonWindowContentHost.ApplicationAccentColor="#19A319"> <Grid Name="RootGrid" Margin="0,0,0,0"> <TreeView x:Name="_foldersItem" Width="Auto" Background="#FFFFFFFF" BorderBrush="#FFFFFFFF" Foreground="#FFFFFFFF"> <TreeView.ItemContainerStyle> <Style TargetType="{x:Type TreeViewItem}"> <EventSetter Event="MouseDoubleClick" Handler="EventSetter_OnHandler" /> </Style> </TreeView.ItemContainerStyle> <TreeView.Resources> <Style TargetType="{x:Type TreeViewItem}"> <Setter Property="HeaderTemplate"> <Setter.Value> <DataTemplate> <StackPanel Orientation="Horizontal"> <Image Name="img" Width="20" Height="20" Stretch="Fill" Source="{Binding RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={x:Type TreeViewItem}}, Path=Header, Converter={x:Static classes:HeaderToImageConverter.Instance}}" /> <TextBlock Text="{Binding}" Margin="5,0" /> </StackPanel> </DataTemplate> </Setter.Value> </Setter> </Style> </TreeView.Resources> </TreeView> </Grid> </igWpf:RibbonWindowContentHost></igWpf:XamRibbonWindow>
thanks
Hello Jean-Pascal,
Were you able to resolve your issue?
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
I am a little confused on what you are trying to do as your XAML does not contain an actual XamRibbon or a XamTabControl. One short answer would be if you had one of these controls on the page you could use the VisualTreeHelper to walk the tree and get the child items.
Please let me know what controls you are using and why you would like to get the visual controls representing each tab so that I can be of further assistance.
Sincerely,
Valerie
