Below are 2 snippets of code for the VM that builds the chart, and the VM that applies the data to show the chart:The Chart VM:
if (axisVm is CategoryDateTimeXAxisVM)
CategoryDateTimeXAxisVM vm = (CategoryDateTimeXAxisVM) axisVm;
CategoryDateTimeXAxis categoryDateTimeAxis = new CategoryDateTimeXAxis();
categoryDateTimeAxis.Label = vm.Label;
categoryDateTimeAxis.DateTimeMemberPath = vm.DateTimeMemberPath;
categoryDateTimeAxis.MinimumValue = DateTime.Now.AddYears(-50);
categoryDateTimeAxis.MaximumValue = DateTime.Now;
//BindingOperations.SetBinding(categoryDateTimeAxis, CategoryDateTimeXAxisVM.MinimumDateTimeProperty,
// new Binding("MinimumDateTime") { Source = vm, Mode = BindingMode.TwoWay });
//BindingOperations.SetBinding(categoryDateTimeAxis, CategoryDateTimeXAxisVM.MaximumDateTimeProperty,
// new Binding("MaximumDateTime") { Source = vm, Mode = BindingMode.TwoWay });
axis = categoryDateTimeAxis;
BindingOperations.SetBinding(axis, CategoryAxisBase.ItemsSourceProperty,
new Binding("Rows") {Source = chartVm});
axis.LabelSettings = new AxisLabelSettings
Location = xAxis++ % 2 == 0
? AxisLabelsLocation.OutsideBottom
: AxisLabelsLocation.OutsideTop,
Visibility = Visibility.Collapsed
if (xAxis == 1)
axis.LabelSettings.Visibility = Visibility.Visible;
The VM tied to the View
if (earliest != null)
if (earliest.MonthDate != null)
DateTime dt = earliest.MonthDate.Value;
DatumTimeChart.X1.MinimumDateTime = dt;
//DatumTimeChart.X2.MinimumDateTime = dt;
The commented out bindging in the first code snipped causes all the axes lines to appear, and possibly be out of sync. The way it shows (the uncommented sections) it works. It should be noted that the second snipped is in an asyn method and has to be due to the amount of data.
Any suggestions on how to bind the value of the Min/Max axes values when called?
You're very welcome. Just let me know if you have any further questions regarding this matter.
That worked, thank you for your help!
Hi Keicha,
The only thing I see weird about the binding code is the second parameter for SetBinding. The second parameter is supposed to be a DependencyProperty present in the first parameter. The first parameter is currently set to the CategoryDateTimeXAxis but the second parameter used is a DependencyProperty on CategoryDateTimeXAxisVM. You should change the SetBinding method to be:
BindingOperations.SetBinding(categoryDateTimeAxis, CategoryDateTimeXAxis.MinimumValueProperty, new Binding("MinimumDateTime") { Source = vm, Mode = BindingMode.TwoWay }); BindingOperations.SetBinding(categoryDateTimeAxis, CategoryDateTimeXAxis.MaximumValueProperty, new Binding("MaximumDateTime") { Source = vm, Mode = BindingMode.TwoWay });
Other than that, everything looks fine. I created a sample which used code similar to yours for the binding and it appears to be working properly. I added a button to my UI that when pressed will add a day to the MaximumDateTime property in the VM. When I press it I can see the chart updating accordingly.
