1690
Field displays full string value only in edit mode
I use NetAdvantage 2012 vol.1 and I have a xamDataPresenter as a grid with only one displayed editable column binded to string value in ObservableCollection. I have some record in the collection where value = 'ORIG CONT 12/31/2013'. Grid displays truncated value to 'ORIG CONT':
Inactive row
but when I click the field and go to edit mode, it displays full value available to edit:
Active row
The grid is defined as:
<igDP:XamDataPresenter Name="xamDataGridContinuityHist" Grid.Row="0" Grid.Column="0"
HorizontalAlignment="Stretch" VerticalAlignment="Stretch" ActiveDataItem="{Binding SelectedEmployeeContinuityHistory,Mode=TwoWay}"
BindToSampleData="False" DataSource="{Binding EmployeeContinuityHistories,Mode=TwoWay}" GroupByAreaLocation="None"
Theme="[current]" Padding="0,0,7,0" BorderThickness="0,0,10,0" ScrollingMode="DeferredWithScrollTips" ScrollBehaviorOnListChange="PreserveRecordsInView">
<igDP:XamDataPresenter.Resources>
<Style x:Key="NotesFieldStyle" TargetType="{x:Type igEditors:XamTextEditor}">
<Setter Property="TextWrapping" Value="Wrap" />
<Setter Property="TextBlock.Background" Value="Brown" />
<Setter Property="Background" Value="LightSteelBlue" />
<Setter Property="AcceptsReturn" Value="True" />
<Setter Property="Selector.SelectedIndex" Value="0" />
<Setter Property="Selector.SelectedValue" Value="" />
</Style>
</igDP:XamDataPresenter.Resources>
<igDP:XamDataPresenter.FieldLayoutSettings>
<igDP:FieldLayoutSettings AllowAddNew="True"
AddNewRecordLocation="OnBottom"
AllowDelete="False"
AutoArrangeCells="Never"
AutoGenerateFields="False"
DataErrorDisplayMode="ErrorIconAndHighlight"
HighlightPrimaryField="Highlight"
SupportDataErrorInfo="RecordsAndCells" SelectionTypeCell="None" />
</igDP:XamDataPresenter.FieldLayoutSettings>
<igDP:XamDataPresenter.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:Field Name="NOTES" Width="400" Column="0" Label="Notes" Row="1">
<igDP:Field.Settings>
<igDP:FieldSettings AllowEdit="True" EditorStyle="{StaticResource NotesFieldStyle}" />
</igDP:Field.Settings>
</igDP:Field>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataPresenter.FieldLayouts>
<igDP:XamDataPresenter.FieldSettings>
<igDP:FieldSettings AllowEdit="True" CellClickAction="EnterEditModeIfAllowed" />
</igDP:XamDataPresenter.FieldSettings>
<igDP:XamDataPresenter.View>
<igDP:GridView>
<igDP:GridView.ViewSettings>
<igDP:GridViewSettings Orientation="Vertical" />
</igDP:GridView.ViewSettings>
</igDP:GridView>
</igDP:XamDataPresenter.View>
</igDP:XamDataPresenter>
I tried to create a sample project with exact the same grid and data and it works fine, i.e. displays complete value. What could be a reason of this behavior ?
Ed
