As the question says, i want to use an image of an open folder if the node is expanded, and a closed folder if the node is not expanded. I have a DataTemplate already, but can'tfigure out how to make a trigger for this that depends of the node's IsExpanded property. Here's my existing XAML, showing an icon but without any code for switching the image source:
<igDT:NodeLayout Key="ReportFolder" TargetTypeName="ReportFolder" DisplayMemberPath="FolderName" > <igDT:NodeLayout.ItemTemplate> <DataTemplate> <StackPanel Orientation="Horizontal" > <Image Source="/Resources/Icons/closed_folder.png" /> //this is where I need a trigger to select open_folder.png if IsExpanded <TextBlock Text="{Binding Data.FolderName}"/> </StackPanel> </DataTemplate> </igDT:NodeLayout.ItemTemplate> </igDT:NodeLayout>
Hello Travis,
Rather than defining a NodeLayout.ItemTemplate, I would recommend that you look into the ExpandedIconTemplate and CollapsedIconTemplate values of the XamDataTree. If you set these to a DataTemplate with an Image inside, they will change based on whether the node is expanded or collapsed.
Sincerely,AndrewDeveloper Support Engineer IInfragistics Inc.www.infragistics.com/support
