4155
Applying Office2013 Theme to MS Core Controls results in incorrect CheckBox state
When i have a MS CheckBox with IsEnabled=false and IsChecked=false, the checkbox displays on the screen with a check in it!  Please see attached sample.  Removing your theme corrects this issue.
ThemeTest.zip
  • 34810
    Verified Answer
    Hello Travis,
    I have reproduced this issue with the check box in the Office2013 theme and a workaround exists for this issue. If you merge the igThemes:PrimitivesOffice2013 theme in your App.xaml rather than the one you are currently merging, the check box issue no longer exists in the project.
    This is still unexpected behavior though, so to ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 181687.  The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
    I have made this case viewable to you. It has an ID of CAS-144148-H7N0M7. You can also continue to send updates to this case at any time.
    You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
    Please let me know if you need more information.
    Sincerely,
    Andrew
    Developer Support Engineer I
    Infragistics Inc.
    www.infragistics.com/support
