170
Unbound field radio button select when calling InitializeRecord
I have a XamDataGrid with several bound columns and one unbound column, a radio button column.  What I want to do when calling InitializeRecord is to set the radiobutton as selected for the first record added ( so there is at least one radiobutton selected ).  Here is the style template for the radiobutton:
<Style x:Key="rbInCellStyle" TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}" >
<RadioButton GroupName="CellButton" HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="False" Click="RB_Click" />
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
Inside InitializeRecord, I do this for the other bound columns:
object typeValue = (e.Record as Infragistics.Windows.DataPresenter.DataRecord).Cells["PeakDefType"].Value;
string tempstr = typeValue.ToString();
            (e.Record as Infragistics.Windows.DataPresenter.DataRecord).Cells["TypeAsString"].Value = typeValue;
How do I do something similar for an unbound column?
