I have a XamGrid and I want to be able to get the underlying row info when I hover over the row. I have the rows change background color when there is a mouse move over a row. Here is the xaml for that piece:
<UserControl.Resources>
<SolidColorBrush x:Key="CellItemSelectedBorderBrush" Color="#FF6DBDD1"/>
<SolidColorBrush x:Key="CellItemSelectedBackgroundBrush" Color="Yellow"/>
<SolidColorBrush x:Key="CellItemAltNormalBackgroundBrush" Color="#FFF6F9FC"/>
<SolidColorBrush x:Key="CellItemNormalBackgroundBrush" Color="#FFFFFFFF"/>
<SolidColorBrush x:Key="CellItemNormalBorderBrush" Color="#FFC9CACA"/>
<SolidColorBrush x:Key="CellRowHoverBackgroundBrush" Color="LightBlue"/>
<SolidColorBrush x:Key="GridRowBackgroundBrush" Color="White"/>
<Style TargetType="ig:CellControl">
<Setter Property="FontSize" Value="11" />
<Setter Property="VerticalContentAlignment" Value="Center" />
<Setter Property="Background" Value="{StaticResource GridRowBackgroundBrush}"/>
<Setter Property="BorderBrush" Value="{StaticResource CellItemNormalBorderBrush}"/>
<Setter Property="BorderThickness" Value="0"/>
<Setter Property="HorizontalContentAlignment" Value="Left"/>
<Setter Property="Padding" Value="5"/>
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="ig:CellControl">
<Grid>
<VisualStateManager.VisualStateGroups>
<VisualStateGroup x:Name="CommonStates">
<VisualState x:Name="Normal" />
<VisualState x:Name="MouseOver">
<Storyboard >
<ObjectAnimationUsingKeyFrames BeginTime="00:00:00" Duration="00:00:00" Storyboard.TargetName="AltMouseOver" Storyboard.TargetProperty="Fill">
<DiscreteObjectKeyFrame KeyTime="00:00:00" Value="{StaticResource CellRowHoverBackgroundBrush}"/>
</ObjectAnimationUsingKeyFrames>
</Storyboard>
</VisualState>
<VisualState x:Name="Alternate" >
<Storyboard>
<DiscreteObjectKeyFrame KeyTime="00:00:00" Value="{StaticResource CellItemAltNormalBackgroundBrush}"/>
</VisualStateGroup>
<VisualStateGroup x:Name="SelectedStates">
<VisualState x:Name="NotSelected" />
<VisualState x:Name="Selected">
<ObjectAnimationUsingKeyFrames BeginTime="00:00:00" Duration="00:00:00" Storyboard.TargetName="ActiveSelected" Storyboard.TargetProperty="Background">
<DiscreteObjectKeyFrame KeyTime="00:00:00" Value="{StaticResource CellItemSelectedBackgroundBrush}"/>
<ObjectAnimationUsingKeyFrames BeginTime="00:00:00" Duration="00:00:00" Storyboard.TargetName="ActiveSelected" Storyboard.TargetProperty="BorderThickness">
<DiscreteObjectKeyFrame KeyTime="00:00:00" >
<DiscreteObjectKeyFrame.Value>
<Thickness>0</Thickness>
</DiscreteObjectKeyFrame.Value>
</DiscreteObjectKeyFrame>
<VisualStateGroup x:Name="ActiveStates">
<VisualState x:Name="InActive" />
<VisualState x:Name="Active">
<DiscreteObjectKeyFrame KeyTime="00:00:00">
</VisualStateManager.VisualStateGroups>
<Border BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" Background="{TemplateBinding Background}" x:Name="Root"/>
<Rectangle x:Name="AltMouseOver" Margin="{TemplateBinding BorderThickness}"/>
<Border x:Name="ActiveSelected" BorderBrush="{StaticResource CellItemSelectedBorderBrush}" ></Border>
<ContentPresenter VerticalAlignment="{TemplateBinding VerticalContentAlignment}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" Margin="{TemplateBinding Padding}"/>
</Grid>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
</UserControl.Resources>
The hover works great ( turns the row background to blue ), but I need to know which row the mouse is over so I can get the underlying data. Thanks for the help.
Hi Kathy,
I hadn’t heard back from you. I was wondering if you had further questions.
Please let me know if I can help further.
You can add a MouseEnter event setter to your CellControl style
<EventSetter Event="MouseEnter" Handler="CellControl_MouseEnter" />
and then use the cellControl's DataContext to look at the row data. In my case the row items are defined by a GridData class.
void CellControl_MouseEnter(object sender, RoutedEventArgs e)
CellControl c = sender as CellControl;
GridData data = c.DataContext as GridData;
Hope this helps. Please let me know if you have any questions.
