1915
Ability to display bound Text and Image in the same cell in XamDataGrid
Searched the forums but did not find a clear solution. I need a way to have an image and cell text to be displayed at the same time. I am able to display either in two separate columns. I have attempted to modify default CellValuePresenter style but its unclear how precisely the binding should be set. Assume I have the following structure in XAML:
<igDP:XamDataGrid>
<igDP:XamDataGrid.Resources>
<Style x:Key="imageStyle" TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
<Image Source="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}" />
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
</igDP:XamDataGrid.Resources>
<igDP:Field Name="Status">
<igDP:Field.Settings>
<igDP:FieldSettings FilterLabelIconDropDownType="MultiSelectExcelStyle"/>
</igDP:Field.Settings>
</igDP:Field>
<igDP:Field Name="StatusImageURI" Label="Status">
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource imageStyle}"/>
</igDP:Field>
So columns for Status and StatusImageURI contain the text and the Image to be displayed. I suppose another way to do this would be to merge these two columns. Any solution is acceptable. Thanks.
