180
XamDataChart WindowRect as Range
Hi IG Team,
to show only a specific part of the chart one can change the WindowRect property of the chart but this rect accepts only 0 till 1 representation for width, height, x and y. My question is:
Is it even possible to show a part of the chart with the correct x, y, width and height parameters to avoid recalcualting these parameters into 0 till 1 representation?
Example:
CategoryXAxis goes from 10 to 20
Visible part should be between 15 and 20
Rect of the chart would use x: 0.5 and width: 0.5 but I want to set x: 15 and width: 5
Many thanks,
Hendrik
  • 34810
    Verified Answer
    Hello Hendrik,
    At the moment, I am unaware of a way of showing a certain part of the chart outside of having multiple data sources for the chart or using the Zoombar with it.
    If you would like to see a non 0-to-1 representation implemented into the XamDataChart, you can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
    There are many benefits to submitting a product idea:
    -          Direct communication with our product management team regarding your product idea.
    -          Notifications whenever new information regarding your idea becomes available.
    -          Ability to vote on your favorite product ideas to let us know which ones are the most important to you.  You will have ten votes for this and can change which ideas you are voting for at any time.
    -          Allow you to shape the future of our products by requesting new controls and products altogether.
    -          You and other developers can discuss existing product ideas with members of our Product Management team.
    Steps to create your idea:
    1.       Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
    2.       Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
    3.       Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
    The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Thank you for contacting Infragistics.
    Sincerely,
    Andrew
    Developer Support I
    Infragistics Inc.
    www.infragistics.com/support
