this seems to be a potential bug.
Earlier I had bound my field like this.
<igDP:UnboundField Name="Qty" Binding="{Binding Quantity, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" Label="Quantity" />
As soon as I was updating the Quantity field the property changed event was firing. So far so Good.
Now i needed to add a conditional mask to the Quantity field, so i modified my xaml to.
<igDP:UnboundField Name="Qty" Binding="{Binding Quantity, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" Label="Quantity" > <igDP:UnboundField.Settings> <igDP:FieldSettings> <igDP:FieldSettings.EditorStyle> <Style TargetType='{x:Type igEditors:XamNumericEditor}'> <Setter Property="Mask" Value="{Binding Path=DataContext.TradeEditorState.QtyMask, RelativeSource = {RelativeSource FindAncestor, AncestorType={x:Type igDP:XamDataGrid}}}"/> <Setter Property="Background" Value="Transparent" /> Style> igDP:FieldSettings.EditorStyle> igDP:FieldSettings> igDP:UnboundField.Settings> igDP:UnboundField>
This caused the immediate property changed event to break, only when i tab out of the Quantity field does the the property change event get fired.
As i am updating the value the property change event does not get fired as it used to fire before.
Hello Raul,
I am just checking your progress on this issue. Please do not hesitate to let me know if you have further questions on this matter.
I am attaching the sample.
Where is the sample app ? I think you forgot to attach it
Thank you for your post!
I have been looking into your issue and I was not able to reproduce it. I have created a small sample application to test this issue. In the sample application I have a simple collection bound to the XamDataGrid. What I can suggest is to use Field instead of UnboundField if the property you are binding to is from the Collection bound to the XamDataGrid. The in my sample application I am setting a Style for the XamNumericInput and I am setting the mask property too.
Would you please modify the sample application attached with the functionality you are using, so it shows the issue. This way I would be able to reproduce it and provide you with further support.
Thank you for the cooperation. Looking forward to hearing from you.
