1230
xamDataChart Legend Marker visibility
Good day,
I have a xamChart which is populated with series programmatically.  The user has the option to turn on markers containing data values, which is done through a DataTemplate as follows:
Background="WhiteSmoke"
BorderBrush="{Binding Series.ActualMarkerOutline}"
BorderThickness="1">
Text="{Binding Item.AxisYValueFormatted}"
Foreground="Black"
FontSize="12"
HorizontalAlignment="Center" />
And assigned in C# using:
chartSeries.SetValue(Infragistics.Controls.Charts.MarkerSeries.MarkerTemplateProperty, this.FindResource("markerValueDataTemplate"));
I need to hide the empty marker balloons in the Legend representation of each series, as the visuals don't work very well.  Is this possible?
Thanks in advance,
Reinhardt
  • 1230
    Verified Answer
    Apologies for replying to my own post :)
    The solution is to add a visibility converter to the DataTemplate which binds to the [Item] object.  The [Item] object is null when the DataTemplate is rendered for the legend.
    The Converter:
    public class EmptyValueToVisibilityConverter : IValueConverter
    public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
    if ((value == DBNull.Value || value == null) == false &&
    value.ToString().Trim().Length > 0)
    return Visibility.Visible;
    else
    return Visibility.Collapsed;
    public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
    return null;
    And the modified DataTemplate:
    <DataTemplate x:Key="markerValueDataTemplate" x:Name="MarkerValueDataTemplate">
    <Grid Height="20" Margin="0, -25, 0, 0" Visibility="{Binding Item, Converter={StaticResource emptyValueToVisibility}}">
    <Border CornerRadius="5"
    <TextBlock Margin="2"
    Foreground="Black"
    FontSize="12"
    </Border>
    </Grid>
    </DataTemplate>
