Why does my Version Utility never work? This is the fourth upgrade i have gone through and it ALWAYS says "appears to be read-only or not accessible for some reason." EVERY TIME. I attached the resultant log file. If it matters, this solution is under source control with TFS. I've tried from inside Visual Studio and from the Infragistics folder in the start menu, neither works ever.
Hello Travis,
When the solution that is being upgraded with the Version Utility is under a source control in TFS it may not be accessible by the upgrader with writing permissions. You can have a look at the following forum thread where Elizabeth shared steps for upgrading in this case: http://es.infragistics.com/community/forums/p/53617/277886.aspx
Please feel free to let me know whether this helps.
