I have a xamtab control with two tabs. Following are my requirements
1. I have a checkbox which when selected hides the second tab (Including the contents of the tab). This I can get it done using header visibility as collapsed
2. Now my first tab is the only visible item. THis tab has a xamdatagrid control in it. What I want is when the second tab has been collapsed I want this first tab header alone to be collapsed. What I mean is the datagrid should be visible in the tab control but the tab header should disappear. This enables saving the vertical space in the screen which is occupied by the tab's header.
Chev
Hello Ranjith,
I am glad that I was able to help. Regarding the post you have provided I can see that Marianne has already replied to the post.
Please do not hesitate to let me know if you have any further questions on this matter.
Fantastic. Thanks, it works.
Not sure if I can ask but could you please help with the below post
http://es.infragistics.com/community/forums/t/89138.aspx
Thank you for your post.
I have been looking into your issue and have created a small sample application for you. In the sample application I have a style which targets the TabItemEx. The style sets the visibility of the first items in the XamTabControl. When there is a second tab added in the XamTabControl both of the tab headers would be visible.
Please find the attached sample application and feel free to let me know if you have any further questions on this matter.
