I want to modify the IsExpandable property with Converter, but i can't do it. Any idea? thanks
<igDP:Field Name="Excepciones" > <igDP:Field.Settings> <igDP:FieldSettings> <igDP:FieldSettings.CellValuePresenterStyle > <Style TargetType="{x:Type igDP:CellValuePresenter}"> <!--<Setter Property="Visibility" Value="{Binding Path=DataItem, Converter={StaticResource ConvTieneHijosDos}}" />--> <!--<Setter Property="ToolTip" Value="{Binding Path=DataItem.TituloProyecto}"></Setter>--> <!--<Setter Property="Visibility" Value="{Binding Path=DataItem.TituloProyecto}"></Setter>--> <Setter Property="Visibility" Value="Collapsed" /> <Setter Property="IsExpandable" Value="False" /> <Style.Triggers> <!--<DataTrigger Binding="{Binding Path=DataItem, Converter={StaticResource ConvTieneHijos}}" Value="True"> <Setter Property="Visibility" Value="Visible" /> </DataTrigger> <DataTrigger Binding="{Binding Path=DataItem, Converter={StaticResource ConvTieneHijos}}" Value="False"> <Setter Property="Visibility" Value="Collapsed" /> </DataTrigger>--> <!--<DataTrigger Binding="{Binding Path=DataItem.EsGanadora}" Value="0"> <Setter Property="Visibility" Value="Collapsed" /> </DataTrigger>--> </Style.Triggers> </Style> </igDP:FieldSettings.CellValuePresenterStyle > </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
Hello Igor,
Thank you for your post. I have been looking into it and I can say that the CellValuePresenter class doesn’t have an IsExpandable Property. The Field class has such Property, but since the Field element is not part of the visual tree you cannot bind its Properties using the DataContext. The only way to bind it is using a StaticResource. Please let me know if you have further questions on this matter.
