All: All:
We have an WPF application using MVVM, PRISM and the XamTileManager 13.2. Views are injected dynamically into the xamTileManager using prism. Basically, each tile represents one view. The structure is as follows:
SessionTemplateView (WPF Tab Control)
PTMTileTemplateView: View injected into Session Template Region
MasterRegion (WPF ItemsControl)
TileManagerTemplateView - View injected into Master region
TileManagerRegion with xamTileManager
PTMPayTemplateView - View Injected into TileManager Region
PaymentsRegion(WPF ItemsControl)
PaymentsView injected into PaymentRegion
PaymentAmountsView injected into PaymentsRegion
PTMPenTemplateView - View Injected into TileManager Region
PenaltiesRegion(WPF ItemsControl)
PenaltiesView injected into PenaltiesRegion
PenaltyAmountsView injected into PenaltiesRegion
RLRegion (WPF Items Control)
Every view has a corresponding view model. We have a concept of a session. Each session contains the TileManagerTemplateView. When we close the session we remove the region and publish shutdown events to all the views. All the views and view models have Finalize events that dispose the VM and view. The View and VM in the RL Region, which are not injected into the TileManagerRegion, do get unloaded from memory when the session is closed. Also, the Views from the Master Region get unloaded as well. The issue seems to be the VMs in the Master Region which contains the TileManager. Not only do they not get unloaded, a new instance of the view model gets created every time the tile gets expanded. The VMs do not have any data in the collections, lists etc., but they do remain in memory. We are not sure how to remove these View Models or how to prevent them from being created in the first place.
Any help or recommendations will be highly appreciated.
Adolfo
Question - did you write a Prism RegionAdapter for the xamTileManager? If so there might be some extra clean-up you need to do in the region's view CollectionChanged event for the 'remove' action. I'd be happy to take a look at you region adapter to help diagnose this. If you did not (which I'm not even sure is possible to make work without) you would likely need one.
Feel free to email on damon.carr@pimco.com to discuss in additional detail.
Damon
Hello Adolfo,
Thank you for your post. I have been looking into it, but since this is not a known issue and I cannot be completely sure how your data is organized and how you implement PRISM, I am not able to conclude what can cause such behavior, so could you please send me an isolated sample project, where this is reproduced and steps to follow, so I can test it for memory leaks?
