Hi
I need to create a summary with difference between sum of 2 fields (sum(a) - sum(b)). The fields that need to be calculate are not show in the grid to achieve simplicity. How should I do this efficiently?
Thank you for your post. I have been looking into it and I can suggest you create a custom summary calculator. Here it is described step by step how to do so:
http://help.infragistics.com/Help/Doc/WPF/2013.2/CLR4.0/html/xamDataPresenter_Creating_a_Custom_Summary_Calculator.html
Please let me know if this helps you or you have further questions on this matter.
