i want to do some styling for xamNumericInput.
1.Spin Button(up/down) : BackGround to #232323 and arrow to black2.TextBoxLineDrawingVisual : when user enter text in the xamNumericInput textBox there is one white line is getting shown like e.g. "_____546.0" i want to change it to " 546.0".3.when user edit it/ change the text of it. BorderBrush : Grey (currently lightBlue).
a sample style would be great.
Regards,Kamlendra
Hello Kamlendra,
I have modified the sample, so now it works as you want. Basically I changed the PromptChar to be "" instead of " ". I also changed the colors as per your requirements. Please let me know if this helps you or you have further questions on this matter.
Hi Stefan,
point number 2 is solved by PromtChar="". Thanks!!but the style which you have shared is screwing up the appearance of the controla)when entering the value. --- text shifting left-right abruptly. b)up/down value blinks....
so, i am not using this style(i don't need that much customization.). i don't want to include the spin button inside my text input box let it outside only .simple change: BgBorder -->GreyspinButtonStyle background -->Grey
Hello kamlendra,
Thanks again.
i already referred the dlls . using Border was key. Thank you!!
You should add the InfragisticsWPF4.Controls.Editors.XamMaskedInput and InfragisticsWPF4 dlls manually since the sample is build under version 13.2. Also in the XamNumericInputs template there is an element called MainBorder, the first element in the ControlTemplate and it is a ValidationDecorator, which is not available in version 11.2, so you should change it to be Border. Please let me know if this helps you or you have further questions on this matter.
