1590
Preventing edit mode from ending on row-base
Hi, I'm trying to change the XamDataGrid's behavior, but I can't seem to get it working the way I want it to. The requirement is that, when a user is editing a row, the user should not be able to leave the row while it is invalid (and so it should stay in edit mode). However, the user should still be able to switch between cells because sometimes an object's validation state is determined by multiple properties (e.g. the From and Till properties in the sample).
The data object implements IDataErrorInfo and IEditableObject in order to support these functionalities.
Can you get my attached sample project working with these requirements?
Please take a look at Readme.txt, which is part of the Visual Studio solution. It contains more detailed technical information.
One more side question; when I set the wrong value for Icon (Red), and then press ESCAPE to roll back, I see some binding errors about PreDropDownAreaTemplate and PostDropDownAreaTemplate in the Visual Studio output window. Why is this?
Kind regards, Stefan
EditableObjects.zip
