Hello Infragistics Support!
I am trying to save an image file (e.g. Tiff-File) from an XamPdf417Barcode-Control.I already tried the sample code and converted it to my needs.
The problem I have, is that part of the code is cut off in the image.So the image-file scaling i not correct.
I've attached my small test program - so you can see what I did.
I hope you can help me.
Best regardsStefan Schmitt
Hello Stefan,
I'm glad you have resolved your issue. Let me know if you have any further questions on this matter.
Hello Rob!
That did it! With your sample it worked.
The margins and the alignment properties are throwing off the RenderTargetBitmap. If you place the XamPdf417Barcode control inside a Grid and you apply the margin and alignment properties to the grid instead, it will export properly.
<Grid Grid.Column="1" Grid.Row="1" Margin="5" HorizontalAlignment="Left" VerticalAlignment="Top"> <ig:XamPdf417Barcode x:Name="DmcPdf417Output" Data="{Binding Text, ElementName=TextBoxInputText}" /> </Grid>
