I have created :
<Style.Triggers> <MultiDataTrigger><MultiDataTrigger.Conditions><Condition Value="False"><Condition.Binding><PriorityBinding><Binding Path="DataItem.value1" /></PriorityBinding></Condition.Binding></Condition></MultiDataTrigger.Conditions><Setter Property="TextBlock.Foreground" Value="#727272"/><Setter Property="TextBlock.FontStyle" Value="Italic"/></MultiDataTrigger></Style.Triggers>
and also have set XAMDataGrid have set HighlightAlternateRecords="False".
All the records are with DataItem.value1 = False.
But still the rows in grid are with alternate style
1. one with Black
2. and others with style mentioned above.
Any fix for this issue.
even the HighlightAlternateRecords="False". not taking effect.
Hello Ravi,
Thank you for your post. I have been looking, but since I cannot be completely sure how your data is organized and on which element you use this Trigger, I am not able to conclude what can cause your behavior, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
