I am using column grouping functionality of xamGrid, which in the worst case may have upto 3 group columns and around 400 columns at the lowest level (4 column headers in total) . The issue is xamGrid performance degrades significantly as you increase the no. of group column. It works just fine when there are 2 group columns but with 3 group and 25 columns it becomes unresponsive and doesn't allow you to click inside or move the scrollbar.
In debugger when I break the execution I can see the Infragistics code(mostly the call to MeasureOverride or ArrangeLayout) at the top of the call stack. Thus it is the xamGrid code alone responsible for poor performance.
I have also attached an isolated project which illustrates this issue. I have tried running the project with the latest release(13.2) of NetAdvantage which didn't improve the performance either. I tried service release 2036 as well but no luck.
Can anyone suggest how I can optimize this or if there is a a fix out there that I am not aware of.
Abdullah Atta
Hello Abdullah,
Thank you for your post. I have been looking into it and I can say that this behavior is expected since only the highest level columns in the GroupColumns are virtualized. I can suggest you remove the Grouped columns in order to keep the virtualization and make the XamGrid responsive. Please let me know if you have further questions on this matter.
