I am setting up a XamDataGrid control:
Currently, the header line (field names) is displayed at the top of the grid and also for each set of child records when a parent record is expanded.
Is there any way to set the grid up so that the header line is displayed only at the top, and not for each expanded child level?
I have tried using LabelLocation="Hidden" but then the top-level headers disappear as well.
Hi Pavel,
Glad I could help.
Excellent, this solved my problem!
Pavel
The simple answer is that you can define the parent and child layouts without the Fields defined and still set the AutoGenerateFields to True so that the fields are generated. Then you add the FieldLayoutSetting LabelLocation set to Hidden to the child layout.
I also wired up the AssigingFieldLayoutToItem event and assign the parent and child layouts.
I’m attaching a sample that may be helpful to you.
