I have dynamic number of columns which are bound to the grid. The columns are pairs Value/State. I want to style the CellValuePresenter for 'Value' to bind certain dependency properties based on 'State'. Since the number or columns are determined at runtime, I can't do it xaml, I need to do it programmatically.
I have created a sample where I am doing it in xaml.
<igDP:Field Name="OneValue" Label="One" > <igDP:Field.Settings> <igDP:FieldSettings> <igDP:FieldSettings.CellValuePresenterStyle> <Style TargetType="{x:Type igDP:CellValuePresenter}" BasedOn="{StaticResource {x:Type igDP:CellValuePresenter}}"> <!--NOTE Binding to different field xxxStale 'Path=DataItem.OneStale'--> <Setter Property="Background" Value="{Binding Path=DataItem.OneStale, Converter={StaticResource BooleanToBrushConverter}}"></Setter> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:Field.Settings></igDP:Field>
Note, in the sample the columns are not dynamic.
Hi Bhavesh,
I am juist checking if you require any further assistance on this matter.
Hello Bhavesh,
Thank you for your post. I have been looking into your question and the following code shows how to write the CellValuePresenter style for the first field in code-behind :
Style MyStyle = new Style(typeof(CellValuePresenter));
Binding myBinding = new Binding() { Path = new PropertyPath("DataItem.OneStale"), Converter = new BooleanToBrushConverter() };
MyStyle.Setters.Add(new Setter(CellValuePresenter.BackgroundProperty, myBinding));
xamDataGrid1.FieldLayouts[0].Fields[0].Settings.CellValuePresenterStyle = MyStyle;
You can make this style generation in a method and invoke it with the appropriate parameters for the corresponding field.
Let me know, if you need any further assistance on this matter.
