415
Generic Debugging Question
This is a generic debugging question that arose because of a very specific problem I am having. I have a flat datasource bound to a XamPivotGrid. The PivotGrid works great if I specify that the DataSource use DimensionGenerationMode = DimensionGenerationMode.Property. However, when I define cube metadata and specify that the data source use DimensionGenerationMode.Metadata, I later get an exception when I bind the XamPivotGrid DataContext to this DataSource.
I already know that there is something wrong either with the data I have or with how I defined the Metadata. I just CAN'T figure out what.
So my question is this: Is there any way to enable extra diagnostic debug output in the Infragistics NetVantage WPF Library? I am using version 13.1 of the library so it is a fairly recent version. It would be nice if I could identify better where the problem is being created.
Sincerely,
Louis
