1410
Having TextColumn with nested binding
Hello
We are using XamGrid , v 12.2.20122.2202
The problem we have is hard to explain, but let me try (in this case description will be better than sample app)
In our application we have a XamGrid that ItemsSource is bound to the collection of "RowElement" objects.There are thousands or RowElements.
Now, each RowElement has a collection of "CellElement" objects, there is - let say - about 50 of them.
CellElement has property "Value" - of type sys:double (and of course some other properties, not really relevant here).
The goal is that we generate all those 50 columns from code-behind so that each cell displays the "Value" property - and it's editable. (so if I double click the cell, I can edit it).
The issue is that, no matter how I set up the TextColumns, I cannot have such functionality.
Solution 1:
column.Key = "[index]" // where index is the index of column
In this case, Cell is bound to the "CellElement" object, and TextBlock displays only "namespace.CellElement" instead of Value (which is obvious)
Solution 2:
column.ValueConverter = new MyConverter() // this simply converts CellElement to the CellElement.Value
Now it works with view, but I cannot edit, as underlying data is sys:double, and when edited - it doesn't know what was the CellElement
Solution 3:
column.Key = "[index].Value"
Same as before
Solution we currently use:
We have TemplateColumns instead of TextColumns, where the binding is set to "CellElement" and then data template do the rest.
The problem we have with TemplateColumns is that they make scrolling of the grid completely slow. This is because those DataTemplates are generated from code behind. With TextColumns the performance is remarkable - not even comparable with template columns - but there are those issues we cannot solve.
So there is this question: how to set up TextColumns to work as described?
(Note that we need CellElement objects, as there are some properties inside that drive Cell styling (colors and so on.)
