715
Drah And Drop framework : Wrapping In behavior for MVVM friendly applications
I am trying to write a small framework of my own by wrapping (trying to) the infragistics DragDrop Framework in an attached behavior/ blend behavior.
The difference between the two is while attahced behavior is static blend behavior is instance based. Anyways, coming to the main topic.
I know the following things:
1) To make an UIElement drag source the following code is required. I am fine with this:
<ig:DragDropManager.DragSource>
<ig:DragSource IsDraggable="True"
DragChannels="Animal,Human" Drop="DragSource_Drop">
</ig:DragSource>
</ig:DragDropManager.DragSource>
2) To make an UIElement a drop target the following code is required. I am fine with this too:
<ig:DragDropManager.DropTarget>
<ig:DropTarget IsDropTarget="True" DropChannels="Animal"/>
</ig:DragDropManager.DropTarget>
3) In the code behind, add the following handler:
private void DragSource_Drop(object sender,
Infragistics.DragDrop.DropEventArgs e)
This is a spoiler. as this adds code behind. So I went for attahced behavior. Also, why not take the data required in the drag drop operations frm the ViewModel classes. This will give ViewModel s more control of the view. This idea made me create a couple of interfaces called IDragSource and IDropTarget that would contain all the info required for dragdrop operation.
So here goes my code, inside the behavior class:
var dragSource = AssociatedObject.DataContext as IDragSource;
if (null != dragSource)
var infragisticsDragSource = new DragSource() { IsDraggable = dragSource.IsDraggable, DragChannels = dragSource.DragChannels };
infragisticsDragSource.Drop += DragSource_Drop;
DragDropManager.SetDragSource(AssociatedObject, infragisticsDragSource);
var dropTarget = AssociatedObject.DataContext as IDropTarget;
if (null != dropTarget)
var infragisticsDropTarget = new DropTarget() { DropChannels = dropTarget.DropChannels, IsDropTarget = dropTarget.IsDropTarget };
Clearly, I have the Drop handler in the behavior clas itself:
private void DragSource_Drop(object sender, DropEventArgs e)
foreach (FrameworkElement fe in e.DropTargetElements)
var dropTarget = fe.DataContext as IDropTarget;
if (sender is IDragSource)
dropTarget.OnDropped((sender as IDragSource).DropArgument);
I just cant make it work. Is it some silly mistake I am doing or something being overlooked by me. I have attached the demo application. Please note you will need System.Windows.Interactivity.dll for the blend behavior to work. If you hate blend, just remove that class from the project. No problem. I am fine with the attached behavior way too.
regards,
DragDropFrameworkPOC.zip
