1715
Xam data grid cell fore ground color
hi,
  i had set following styles in xamdatagrid resources
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="BorderThickness" Value="0,1,0,1"></Setter>
<Setter Property="BorderBrush" Value="LightGray"></Setter>
<Style.Triggers>
<Trigger Property="IsRecordSelected" Value="True">
<Setter Property="BorderBrush" Value="Transparent"></Setter>
</Trigger>
</Style.Triggers>
</Style>
<Style TargetType="{x:Type igDP:DataRecordCellArea }">
<Setter Property="BackgroundActive">
<Setter.Value>
<LinearGradientBrush EndPoint="0.5,0" StartPoint="0.5,1">
<GradientStop Color="Gray" Offset="0.569"/>
<GradientStop Color="#FF504E4C" Offset="0.138"/>
</LinearGradientBrush>
</Setter.Value>
</Setter>
<Setter Property ="BackgroundHover" Value="Transparent"></Setter>
<Setter.Value>
</Setter.Value>
</Setter>
</Style>
when i select one row, selected row changes its foreground as my requirement(dark gradient).the problem is i want to set cell text color to white when i select row.
Jafar VM
