405
How to eliminate delay in checking a menu item checkbox
I am using Infragistics default style for XamContextMenu.
The context menu items have checkboxes. The issue is that when a user clicks the checkbox, the check mark takes a few moments to appear. I know this is/can be controlled via the ResourceDictionary style were are using (which was taken initially from the one used by the Infragistics Samples application). But I am unable to determine what controls this behavior.
In that attached sample app, if you right-click on the menu to get the context menu to appear, when you click a menu item the check mark has a slight delay before it is rendered. How can this be made so that the check mark appears as soon as user clicks the checkbox?
Thank you for any help.
--Pat
xamMenuFun.zip
