We are using Infragistics 13.1 and having this issue from time to time using XamDataGrid.
Any ideas?
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.GetFieldsInView()
at Infragistics.Windows.DataPresenter.VisibleDataBlock.Create(List`1 recordPresenters)
at Infragistics.Windows.DataPresenter.RecordsInViewHelper.ShouldProcessRecordManager(RecordManager rm, IList`1 fieldInfos)
at Infragistics.Windows.DataPresenter.RecordsInViewHelper.ShouldProcessInViewRecord(Record record, IList`1 fieldInfos)
at Infragistics.Windows.DataPresenter.AutoSizeFieldHelper.Calculate(RecordEnumeratorBase outOfViewRecords, AutoSizeCalculationFlags flags, RecordFieldList& recordFieldList, Boolean trackRecords, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.PerformAutoSize(Boolean isHorz, IEnumerable`1 autoFields, RecordCollectionBase records, Int32 recordManagerDepth, HashSet recordsSubset, Boolean increaseOnly, OperationType operationType, FieldAutoSizeOptions allowedOptions, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.ProcessPendingOperationsImpl(RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.ProcessPendingOperations(List`1 pendingAutoSize, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.DataPresenterBase.ProcessPendingAutoSizeOperations()
at Infragistics.Windows.DataPresenter.DataPresenterBase.OnPerformFieldAutoSize(Object parameter)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Hello both,
The IndexOutOfRange exceptions occurred when the user selected child records form different parents or during field autosize operation. If your scenario is the same then I can verify that the issues no longer occurs, but since the IndexOutOfRange exception is related to collections I cannot be completely sure what is your scenario.
Hope this helps you.
Hi Stefan and Nick,
It's really hard to reproduce the issue, it's really intermittent and our setup is really complex.
Yes, this seems to be the issue, we we're using 12.2, following that issue I did upgrade to 13.1 (the latest in our company). The first time I open the app with 13.1 that exception got raised a couple of time, since that as far as I know, it never happened again, so maybe it was just a glitch. I will know in the next few weeks if that upgrade resolved the issue we observed.
I'll update the post then.
Dominik
Looks like it's been an issue before:
http://dl.infragistics.com/community/wpf/ReleaseNotes/WPF_ReleaseNotes_12_2_SR_December_2012.pdf
Can you confirm that this defect has actually been fixed? Which version it was fixed in and what the fix was?
Cheers,
Nick.
Thank you for your post. I have been looking into it, but since this is not a known issue I cannot conclude what can cause it, so if you still haven’t resolve thus, could you please send an isolated sample project, where the issue is reproduced, so we can investigate it further for you.
