1240
Expanders Stop Working
I ran into a problem with expanders not showing the contents of a child collection.  I found that when a child collection is cleared out the grid re-evaluates which FieldLayout to use.  Since the contents of the child collection is now empty it has no data type to check against.  I think it then uses the type of collection to check for the FieldLayout to use.  The problem happens when the collection’s type is a base type, but the contents end up being a collection of types derived from the base type.  This causes the grid to not find a FieldLayout to use and creates an empty one.  From there on out, the expanders no longer work.  I’ve created a test app which shows this condition and attached it.  I’ve gotten around this issue by hooking into the AssigningFieldLayoutToItem handler and forcing the FieldLayout.  Is there a better solution that this?
Dan
Grid Expander Test.zip
  • 138253
    Hello again Dan,
    You can also set the Key of the FieldLayout to the type of your base class like this:
    <igDP:FieldLayout Key="{x:Type local:BaseClass}" xmlns:local="clr-namespace:GridTest">
        <igDP:FieldLayout.Fields>
            <igDP:Field Label="" Name="SubCollection" />
            <igDP:Field Label="Property1" Name="Property1" />
            <igDP:Field Label="Property2" Name="Property2" />
            <igDP:Field Label="Property3" Name="Property3" />
        </igDP:FieldLayout.Fields>
    </igDP:FieldLayout>
    Hope this helps you.
  • 138253
    Hello Dan,
    Thank you for your post. I have been looking into it and the sample you have created and I believe that the approach you are using is the best one for achieving the functionality you want. If I think of a better one I will let you know.
