Hi
I have to set border on record whit over expansion means whole DatarecordPresenter when trigger DatarecordCellArea IsActive property.
Adit Sheth
Hello Adit,
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I created a Style for the DataRecordCellArea, so I could be able to remove the default selection of the Records. I also copied the default Style of the DataRecordPresenter and set the BorderBrush and the BorderThikness of a Border called addRowFooter. I also added a DataTrigger, so the border can become visible when the Record is active. Please let me know if this helps you or you need further assistance on this matter.
