Hi, I'm using XamNumericEditor in DataTemplate like this
<DataTemplate x:Key="NumericRangedTemplate" DataType="settings:RangedVisualSetting"><!--Other parts of template--> <igEditors:XamNumericEditor SpinWrap="True" Margin="5" VerticalAlignment="Center" InvalidValueBehavior="DisplayErrorMessage" Width="100" Value="{Binding Value}" DisplayMode="Raw" SpinButtonDisplayMode="Always" ValueType="{x:Type system:Int32}"> <igEditors:XamNumericEditor.PromptChar> <system:Char /> </igEditors:XamNumericEditor.PromptChar> <igEditors:XamNumericEditor.ValueConstraint> <igEditors:ValueConstraint MinInclusive="{Binding MinValue, Mode=OneTime}" MaxInclusive="{Binding MaxValue, Mode=OneTime}" Nullable="False" /> </igEditors:XamNumericEditor.ValueConstraint> </igEditors:XamNumericEditor> </DataTemplate>
Both MaxValue and MinValue has type int? but in my particuar case they are not null (e.g. MaxValue == 100)
Although InvalidValueBehavior is set to "DisplayErrorMessage" I don't get it neither when I clear everything from editor (in this case red border appears around it and I can't leave it which is fine for me since ValueConstraint.Nullable is set to false. But I CAN input any value which exceeds maximum and upon leaving editor it just gets back to maximum. For some reason I see this behavior for any value of InvalidValueBehavior. How can I make it stay in edit mode and don't correct value? Library version 12.1.20121.2059.
P.S. How can I decorate code and markup properly like it is displayed in Visual Studio i.e. with different colors etc?
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post, but it seems like that I am missing something in your scenario, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
Does anyone hear me?)
