Hi,I want to set label text to wrap but label should contain max two lines. Is there any way other than explicitly setting height of label presenter.
Thanks.
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I created a Style for the labelPresenter and set its ContentTemplate to be a Textbox. I make it look like the default Label and set its MaxLines Property to 2. I also set the XamDataGrid’s LabelMinWidth Property to 52, which the min size for showing two full lines, but if you want you can remove it based on your requirements. Please let me know if this helps you or you need further assistance on this matter.
