I have a XamDataGrid. I have configured this setting so that I can disable highlighting on row hover.
<igDP:XamDataGrid.Resources> <Style TargetType="{x:Type igDP:DataRecordCellArea}"> <Setter Property="BackgroundHover" Value="Transparent"/> <Setter Property="BackgroundSelected" Value="Transparent"/> </Style> </igDP:XamDataGrid.Resources>
Now my problem is when I select any cell then that row gets highlighted. I want to remove row highlighting even if I click on some cell.
How this can be done ? Please help.
I have also attached a screenshot of my issue.
Arpita
Thank you, Stefan. I did use all the brushes and now cell is not highlighting
Hello Sergey,
Thank you for your post. I have been looking into it and I can suggest you use the Style for the CellValuePresenter, which I shared in my previous post in order to remove the highlight border of the cells.
Hope this helps you.
Hi Stefan,
I have similar problem - a click on cell highlights it with annoying blue brush. I have disabled all highlighting using DataRecordCellArea style, but cannot get cell background not to change on click.
<Style TargetType="{x:Type igDP:DataRecordCellArea}" >
<Setter Property="BackgroundSelected" Value="Transparent" />
<Setter Property="BackgroundActive" Value="Transparent" />
<Setter Property="BackgroundHover" Value="Transparent" />
</Style>
Is there a way to disable all the highlighting in XamDataGrid ?
Hello Arpita,
Thank you for your post. I have been looking into and I can suggest you use the following two Styles instead of yours:
<igDP:XamDataGrid.Resources> <Style TargetType="{x:Type igDP:DataRecordCellArea}"> <Setter Property="BackgroundHover" Value="Transparent"/> <Setter Property="BackgroundSelected" Value="Transparent"/> <Setter Property="BackgroundActive" Value="Transparent"/> <Setter Property="BorderActiveBrush" Value="Transparent"/> <Setter Property="BorderHoverBrush" Value="Transparent"/> <Setter Property="BorderSelectedBrush" Value="Transparent"/> </Style> <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="BackgroundHover" Value="Transparent"/> <Setter Property="BackgroundSelected" Value="Transparent"/> <Setter Property="BackgroundActive" Value="Transparent"/> <Setter Property="BorderActiveBrush" Value="Transparent"/> <Setter Property="BorderHoverBrush" Value="Transparent"/> <Setter Property="BorderSelectedBrush" Value="Transparent"/> </Style> </igDP:XamDataGrid.Resources>
This way there won’t be any highlight of the Cells or the Records. Please let me know if this helps you or you need further assistance on this matter.
