I upgraded to 11.1 to 13.1, and a XamTextEditor I have that was previously working is showing the following behavior:
1) Enter edit mode by making the cell active or right clicking the cell and choosing rename
2) type in some random garbage
3) hit enter key OR change focus by hitting tab or clicking out
4) the entered value is immediately blanked out and validation fails turning the cell red
Is there some change moving from the IG versions that changes the way EditMode is handled?
Thanks for your help.
Edit: I did some more digging, the text box in the XamTextEditor control that holds the actual text value is fine through the EditModeEnding event, and then suddenly in EditModeEnded, the text box in the control is null.
Hi David/Infragisitics Team,
What's the resolution for this issue? We recently upgraded to 15.1 from 11.2 version and I'm facing the exact same issue with XamTextEditor. Please let us know what's done to fix this issue at the earliest.
Eker.
Hello Prasanti,
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://es.infragistics.com/community/forums/p/70085/354877.aspx
where there is a sample, which you can use as basis in order to achieve the functionality you want.
I have a xamtexteditor and xamdatagrid with two fields.xamtexteditor is a seperate control but not in xamdatagrid.While typing text in xamtexteditor I should get matching records in xamdatagrid.The text should match with either of the fields.And It should be like autocomplete in xamcomboeditor i.e. while typing in xamtexteditor I should get matching records starting with that text.
could please suggest me how to do it.
Hello David,
Could you please send us an isolated sample project, where the issue is reproduced, so we could be able investigate this further for you.
I have run in to this issue yet again, but it seems that support case is now closed.
