910
OnRecordActivated Used To Execute Command
Ive ran into a issue that I cant get around.
 Wondering if anyone else is seeing this.
Ive extended the XamDataGrid, created some DependencyProperties, some to allow the consumer to attach a Command to the DataGrid.
I want to execute this command when the user Selects a Row.  So I override OnRecordActivated method and call this command in it.
This works great the first time the user clicks on the row, but if they click on another row the command doesnt seem to get called.  If I call the command from another button outside of the grid it works fine.  Once I do that, I can click on another row in the gird and it works again.  However trying to click another row doesnt work, unless I run the command from outside of the grid again.
Ive Included my code
Allen
FulfillmentDataGrid.zip
  • 9694
    Hi Allen,
    Did you find a solution to this issue?
    Is the problem that the Command doesn't work or that the overridden method doesn't get called?
    If the method isn't being called, does it work if you assign an event handler to the event?
    I will be glad to look further into this with your code if need be.
    Thank you,
