20
Validate XamDatagrid cell in WPF using MVVM/C#
Iam using XamDatagrid in WPF using MVVM/C#. I have an editable column in the grid with EditModeStart/End commands. These commands have 'get' methods where the code does something just before the starting and ending of a grid cell. Now I want to validate the cell value to make sure its between -100 and 100 with an alert box else I shoudnt permit the user to do anything on the WPF view.
Can someone please help me out?  FYI, All my code is in viewmodel only.
Many thanks in advance,
Ravi
  • 1915
    Verified Answer
    The simplest way to do it in MVVM way is have an attached property hooked up to the CellUpdated routed event in the class on a VM side that will execute an ICommand (like RoutedCommand) on the ViewModel class when the cell's updated and cell exits edit mode. Then, you do your processing/validation within the RoutedCommand method and depending on how you hooked up your Msgbox handle the validation results. See Brian Laguna's blog for details: http://brianlagunas.com/an-mvvm-friendly-property-for-the-xamdatapresenter-doubleclick-event/
