I've 3 column series in one XamDataChart.
The third overlap the first two.
In my application, I want the user to hide or show the second series (Name: Series2)(In the example, the series is manually hidden)
If the series is hidden, the place is blank.
I want the third series to collapse, so the bar is smaller because I don't want that empty room there.
Is there any way to do this? Or is it a bug?
Thank you for your feedback.
Our development team has reviewed this and stated that this is the designed behavior of StackedFragmentSeries as they do not support visibility functionality. A possible solution, that could be used, is to remove/re-add the series from the collection instead. In the attached sample project the second fragment is removed if the user clicks on “Remove series” and re-added if after that the “Add series” button is pressed.
I've just noticed, that if a chart with a hidden series is printed, the complete chart is empty.
My workaround is, that I didn't fill the series with data instead of set the visibility of series to hidden.
Thank you for your post. I have logged this behavior with our developers in our tracking system, with an issue ID of 145138. I have also created a support ticket on your behalf with number CAS-118488-F8L2P9 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
