1865
Fix only top row
My xamDataGrid is sorted by Field1. Field1 has a value "~Total" so this row always appears as the first row. Is there a way to keep this row fixed as the 1st row even if the user re-sorts the data? The AllowRecordFixing feature will work if I could fix this top row programmatically but do not allow the user to fix other rows?
Thanks.
  • 890
    Verified Answer
    Hi
    If you are going to fix records only in code then you do not need to allow record fixing. You can just do this:
    private void XamDataGrid_Loaded(object sender, RoutedEventArgs e)
                XDG.Records[0].IsFixed = true;
                //If you do not wish to see the Record Separator
                XDG.FieldLayoutSettings.RecordSeparatorLocation = RecordSeparatorLocation.None;
    Please let me know if that is what you were looking for or if you have any other questions.
    Slavi
    XdgRecordFixing.zip
