2395
Get GroupByRecordPresenter on child record MouseEnter event
I'm attempting to get the GroupByRecordPresenter on a child record when the mouse moves over it using the following code: I'm setting this on a style for the DataRecordPresenter
		private void OnMouseEnter(object senderMouseEventArgs e)
			RecordPresenter rp = sender as RecordPresenter;
			if (rp == nullreturn;
			Debug.WriteLine("Success!");
			GroupByRecordPresenter gbrp = GroupByRecordPresenter.FromRecord(rp.Recordas GroupByRecordPresenter;
			if (gbrp == nullreturn;
However, GroupByRecordPresenter.FromRecord always returns null, even though the GroupByRecordPresenter is loaded and visible in the grid. How can I obtain the GroupByRecordPresenter on mouseover?
  • 138253
    Hello Dierk,
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 138253
    Hello Dierk,
    Thank you for your post. I have been looking into it and I can say that GroupByRecordPresenter’s From Record method returns the RecordPresenter of a GroupByRecord, not Record, so I can suggest  you use the following code instead of your in order to get the Record’s GroupByRecordPresenter:
    DataRecordPresenter drp = sender as DataRecordPresenter;
    if (drp == nullreturn;
    if (drp.Record.ParentRecord != null)
        GroupByRecordPresenter gbrp = GroupByRecordPresenter.FromRecord(drp.Record.ParentRecord) as GroupByRecordPresenter;
    Please let me know if this helps you or you need further assistance on this matter.
